[gdal-dev] Re: GDAL/WMS and Proxy
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Wed Dec 2 05:00:57 EST 2009
Stefano Moratto <stefano.moratto <at> gmail.com> writes:
> I set proxy information as described but It did not work.
Have you tried to set proxy in the Windows command window first? I believe the
command is
SET http_proxy=server:port
It would be good to have an option to set it in the xml file also.
-Jukka Rahkonen-
