[gdal-dev] GDAL/WMS and Proxy
Stefano Moratto stefano.moratto at gmail.com
Wed Dec 2 04:41:54 EST 2009
Hello,
         I'm experimenting accessing openstreetmap's tiles using GDAL (WMS
minidriver).  I'm using gdaltranslate and the configuration file provided at
http://www.gdal.org/frmt_wms.html.
If the PC, where gdaltranslate is running, is not behind a firewall It works
fine.
In http://trac.osgeo.org/gdal/wiki/SoCWMSDriver it can be read a reference
to a HTTP proxy configuration entry that can be specified in the gdal xml
configuration file describing the dataset.
I set proxy information as described but It did not work. I browsed the code
(I compile the trunk) but I did not find any code that set the proxy option
for lib_curl.
Is this feature planned for a future release?
I have a osgeo id (moratto) and I'm a committer (I'm working on the delphi
binding). I can add this feature and commit the code.
Regards,
Stefano
Dr.Eng. Stefano Moratto
stefano.moratto at csiat.it
http://www.csiat.it - Traffic Optimization Software
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091202/23272052/attachment.html
