[Gdal-dev] gdal build failure on SUSE LINUX Enterprise Server 10
Alans alan.stratford at goodrich.com
Thu Dec 10 10:29:59 EST 2009
Alans wrote:
> Frank Warmerdam wrote:
>> This is very odd - I've never seen something quite like it.
>> One work around would likely be to configure GDAL --without-libtool.  I
>> wonder if 1.6.3 got released with an unstable libtool version.  Could you
>> try 1.6.2 on this system and see if that works?
> Thanks Frank,
> I will try 1.6.2 and get back to you.
> Alan
Yep. 1.6.2 has exactly the same error.
View this message in context: http://n2.nabble.com/gdal-build-failure-on-SUSE-LINUX-Enterprise-Server-10-tp4145777p4145944.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
