[Gdal-dev] gdal build failure on SUSE LINUX Enterprise Server 10
Alans alan.stratford at goodrich.com
Fri Dec 11 12:22:31 EST 2009
Alans wrote:
> Alans wrote:
>> Frank Warmerdam wrote:
>>> This is very odd - I've never seen something quite like it.
>>> One work around would likely be to configure GDAL --without-libtool.  I
>>> wonder if 1.6.3 got released with an unstable libtool version.  Could
>>> you
>>> try 1.6.2 on this system and see if that works?
>> Thanks Frank,
>> I will try 1.6.2 and get back to you.
>> Alan
> Yep. 1.6.2 has exactly the same error.
I have now got the gdal-svn-trunk-2009.12.09 version to build on SLES 10 sp2
by configuring --without-libtool, as Frank suggested.
Thanks
Alan
View this message in context: http://n2.nabble.com/gdal-build-failure-on-SUSE-LINUX-Enterprise-Server-10-tp4145777p4152504.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
