[gdal-dev] Re: Conflicts when using GDAL with minGW
LF lucafasano at interfree.it
Tue Feb 24 03:33:48 EST 2009
Ozy Sjahputera <sjahputerao <at> missouri.edu> writes:
> error: `snprintf' is not a member of `std'
> e:/MinGW/bin/../lib/gcc/mingw32/3.4.2/../../../../include/math.h error:
> declaration of C function `float _copysign(float, float)' conflicts with
> declaration of C function `long double _copysign(long double, long
> double)' conflicts with
> previous declaration `double _copysign(double, double)' here
> previous declaration `float _copysign(float, float)' here
> The following is my GDAL headers included:
> #include <gdal_priv.h>
> #include <cpl_string.h>
> #include <ogr_spatialref.h>
> #include <gdalwarper.h>
> It seems that the GDAL library is causing some functions in the minGW
> C++ library (cstdio) to be undeclared.
> Has anyone experienced this kind of conflict?
> Thanks
> Ozy
Hi
I've a problem like your one.
I tried to compile a PLUGIN for GDAL and I included files as following:
#include gdal_priv.h
#include hdf5.h
#include gdal_pam.h
#include cpl_string.h
#include ogr_spatialref.h
#include cpl_list.h
I had two conflicts between mingw and gdal for variables *_copysign*
and *ssize_t*, defined in both mingw and gdal.
Should I define some macros or other else when I want to compile GDAL
with MinGW?
Someone could help us??
