[gdal-dev] GDAL autotest (nitf_37) causes a crash on Windows
Tamas Szekeres szekerest at gmail.com
Sat Feb 28 14:32:47 EST 2009
Yes, I'll do so in my final configuration.
Thanks,
Tamas
2009/2/28 Even Rouault <even.rouault at mines-paris.org>
> Tamas,
> Yes, nitf_37 won't work against the stable branch.
> Generally speaking, I think you should only run the stable branch with its
> autotest in branches/1.6/autotest, and not trunk autotest, as there are new
> features and bug fixes that go only in trunk and whose testing against
> stable
> can easily crash. Of course, I could make some conditionnal testing on the
> GDAL version to skip that test, but I don't think it's really worse the
> effort as similar issues could appear elsewhere in that autotest suite. And
> even if you don't get crashes, you'll get lots of failed tests.
> Even
> Le Saturday 28 February 2009 20:09:12, vous avez écrit :
> > I've been running against the stable branch. Is this an issue?
> > Best regards,
> > Tamas
> > > Yes, exactly you need latest trunk to run this test.
> > > Le Saturday 28 February 2009 18:53:30 Frank Warmerdam, vous avez écrit
> > > > I was seeing a somewhat similar effect with the latest nitf.py and
> > > > a week old FWTools build but when I refreshed from the latest
> > > > GDAL source the problem went away leading me to suspect that the
> > > > test is for a recent fix put in by Even.  Are you confident you are
> > > > running the test with the latest source?  Perhaps there was a short
> > > > overlap?
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090228/9d9b70e2/attachment.html
