[gdal-dev] Error (Not enough data for scanline) by using gdaladdo with geotiff
Fri Jan 9 13:13:08 EST 2009
Gregor Fikoczek wrote:
> Hi,
> i am using 'GDAL 1.6.0, released 2008/12/04' on (K)Ubuntu 'Linux
> 2.6.22-16-generic i686 GNU/Linux'. By using gdaladdo with a geotiff i get the
> following Result/Error:
> gdaladdo -r nearest test.tif 2 4 8 16
> Warning 1: TIFFReadDirectory:test.tif: Wrong "StripByteCounts" field, ignoring
> and calculating from imagelength
> 0Warning 1: TIFFReadDirectory:test.tif: Wrong "StripByteCounts" field,
> ignoring and calculating from imagelength
> ERROR 1: /home/fikoczek/projekte/bentheim/testbild/8015.9B.tif:DumpModeDecode:
> Not enough data for scanline 0
> ERROR 1: TIFFReadEncodedTile() failed.
> ERROR 1: IReadBlock failed at X offset 0, Y offset 0
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
> ...10...20...30...40...50...60...70...80...90...100 - done.
> Overview building failed.
> Anybody an idea ?????
> Something with the libtiff ???
Greg,
Generally this indicates use of an older libtiff.  If you want to avoid
this, I'd suggest configuring --with-libtiff=internal.
Best regards,
