[gdal-dev] Re: improve PDS and Isis drivers
lidiriel ludovic.mercier at gmail.com
Mon Jan 19 10:08:09 EST 2009
Thanks Trent for your reply.
I'm not sure to have completly understand your reponse (i don't speek
english fluently :( ).
But i have notice the interresting link http://www.orrery.us/node/44
for PDS Meta parser.
I think that i will kept to use gdal and if is necessary for my work i
will created several patch.
I work on a software that it must load PDS file (mainly Isis2 EDR with
separate binary data).
Now i will upload a new patch for get metadata : isis2dataset.patch2
three domains :  "LabelStandards", "FileCharacteristic",
"Identification"
and all other keyword are load in main domain : "".
regards
On 16 jan, 18:31, Trent M Hare <th... at usgs.gov> wrote:
> Lidiriel,
>         All PDS, ISIS2, and ISIS3 drivers should support detached labels
> for the simple raw (or ISIS3 tiled) formats (now the PDS reader doesn't
> support detached JP2 images yet).  There have been a few fixes in the last
> few months for these planetary readers so try to stick with 1.6.x.
> The minimal PDS driver was implemented because it was similar to ISIS2
> thus it is not very robust. The goal for all these drivers was to mainly
> capture the projection information for GIS/RS applications thus it is not
> meant for non-projected or raw PDS (EDR) images. There are MANY
> non-standard PDS images in the wild (e.g. missing projection parameters,
> incorrect offsets for X,Y corners, odd labels), so it can be very hard to
> generate a generic PDS reader which checks for all the known issues. One
> future goals I had was to utilize an existing PDS library to enhance the
> currently used very simple label parser that we wrote and Frank fixed up
> for us. There are a few good library examples discussed here:http://www.orrery.us/node/44. However, PDS3 has a short life span ahead
> of it.  There are talks of a new PDS2010 standard to replace PDS3. This
> will probably be available in 2010 or 2011.
> Simple fixes for current PDS label that would be great for one, like
> yourself, or other to implement.
> 1.) PDS detached label that points to JP2 image. Currently the PDS reader
> only support raw images
> 2.) Band name propagation (or other metadata? that can be easily mapped
> into GDAL).
> But any changes or enhancements would be welcome. I really hope the PDS
> itself will get behind this driver and help to support its ongoing
> development. I think they (PDS at JPL) are using to create browse jpeg
> images for the new Mercury images. There are just not many good readers
> out there for PDS (Nasaview has it place but is not very useful). And
> really hope they will consider GDAL support for the new PDS2010 format -
> whatever that will be. Maybe they will even choose to be compatible to an
> existing format! I can only hope.
> Again, I never meant for this reader to support raw EDR images because
> those come in many different styles of compressions (e.g. MOC can have
> none, discrete cosine transform or  Walsh-Hadamard transform compression).
> It is currently intended for only map-projected raw PDS3 images.
> Regards,
> Trent
> Frank Warmerdam <warmer... at pobox.com>
> Sent by: gdal-dev-boun... at lists.osgeo.org
> 01/14/2009 10:55 AM
> To
> lidiriel <ludovic.merc... at gmail.com>
> cc
> gdal-... at lists.osgeo.org
> Subject
> Re: [gdal-dev] improve PDS and Isis drivers
> lidiriel wrote:
> > hi,
> > I work with several pds files and i have many idea for improve
> > driver :
> > Add several domaine (for obtain a classification) with standard
> > Metadata like describe in "PDS standars reference" document (chapter5
> > v3.7) each domain can contains a minimum number of keys.
> > domaine name (dn): LABEL_STANDARDS
> > keys : PDS_VERSION_ID, DD_VERSION_ID, LABEL_REVISION_NOTE
> > dn : FILE_CHARACTERISTICS
> > keys: RECORD_TYPE, RECORD_BYTES, ...
> > dn : IDENTIFICATION_DATA_ELEMENTS
> > keys: DATA_SET_ID ...
> > implementation of reading a detached data in first time for ISIS2
> > driver :
> > ("filename", nnn) (chapter 5 page 13 of PDS specification v3.7)
> > Many of my data use this last notation and for using gdal i will must
> > implemented this in priority.
> Lidiriel,
> I am reasonably supportive of adding capture and exposure of metadata
> from PDS, ISIS2 and ISIS3 datasets in some appropriate fashion. I'd
> be open to appropriate patches though I'm not inclined to do much more
> directly as implementation than I have already done, unless my original
> client (USGS) demonstrated an interest.
> I believe we do have some support for detached datasets.  Perhaps that
> is only in ISIS3?  I would be happy to have detached support also added
> in ISIS2.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows |http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-... at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
