[Gdal-dev] Changing a color in palette
darrepac pascal.darre at laposte.net
Fri Jan 23 16:49:47 EST 2009
If I have to do a script in Python, I will do it!
So yes please, I would like to see an example
thanks
Frank Warmerdam wrote:
> darrepac wrote:
>> Hello
>> I have a set of geotiff 8bits file.
>> I would like to change 1 color of the palette: puting the color
>> 255,255,255
>> in the index 123 instead of color  255,0,255. While not touching anything
>> else.
>> Is there a way to do this? because I have a big set of files and I did
>> not
>> find any tool which permit batch processing and keep the geo information.
> Darre,
> It should be quite practical to do this with a small python script, but,
> you
> may need to use the trunk version of GDAL to get this functionality.
> There
> was recently a bunch of work done to support more dynamic altering of tiff
> colormaps that you might require.
> I could provide a sample script to do this if you are interested.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
View this message in context: http://n2.nabble.com/Changing-a-color-in-palette-tp2205904p2206046.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
