[Gdal-dev] Changing a color in palette
Fri Jan 23 17:06:42 EST 2009
darrepac wrote:
> If I have to do a script in Python, I will do it!
> So yes please, I would like to see an example
Darre,
With GDAL "trunk" the following seems to do the trick, and could
be easily extended to loop over many files.
import gdal
def update_ct( file ):
     ds = gdal.Open( file, gdal.GA_Update )
     ct = ds.GetRasterBand(1).GetRasterColorTable()
     ct.SetColorEntry( 123, (255,255,255) )
     ds.GetRasterBand(1).SetRasterColorTable( ct )
     ds = None
update_ct( 'test.tif' )
Best regards,
