[gdal-dev] Can I create a GDAL data set from bytes in memory?
Joel Odom joelodom at gmail.com
Wed Jan 28 10:26:24 EST 2009
I've got a situation where I'm trying to use GDAL to read image files
contained within a KMZ archive.  (My project uses both GDAL and libkml.)
 Libkml can easily read the image file into memory out of the KMZ archive,
but I'd like to pass it to GDAL without having to write it to a temporary
file on disk.  I haven't figured out if this can be done yet.  Thanks for
any answers.
http://giscoder.blogspot.com/
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090128/017f1763/attachment.html
