[gdal-dev] Build failure on Mac X
jluis at ualg.pt jluis at ualg.pt
Sun Jul 5 12:20:31 EDT 2009
I do this very rarely but it had worked before. However, today's
attempt to build trunk on OSX is failing at the end with
b/libNCSUtil.dylib -lmfhdf -ldf /usr/local/lib/libsz.dylib
/usr/local/lib/libnetcdf.a -ldl -lcurl -lssl -lcrypto -lz
   -install_name  /usr/local/lib/libgdal.1.dylib
-Wl,-compatibility_version -Wl,15 -Wl,-current_version -Wl,15.0
Undefined symbols:
   "OGRGeometry::dumpReadable(__sFILE*, char const*) const", referenced from:
       vtable for OGRMultiPointin ogrmultipoint.o
       vtable for OGRMultiLineStringin ogrmultilinestring.o
ld: symbol(s) not found
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make: *** [check-lib] Error 2
Joaquim Luis
This message was sent using IMP, the Internet Messaging Program.
