[gdal-dev] Build failure on Mac X
Even Rouault even.rouault at mines-paris.org
Sun Jul 5 13:25:57 EDT 2009
Did you happen to 'svn update' and just 'make' ? If that's the case, you
should do a 'make clean' before trying 'make' again
Le Sunday 05 July 2009 18:20:31 jluis at ualg.pt, vous avez écrit :
> Hi,
> I do this very rarely but it had worked before. However, today's
> attempt to build trunk on OSX is failing at the end with
> b/libNCSUtil.dylib -lmfhdf -ldf /usr/local/lib/libsz.dylib
> /usr/local/lib/libnetcdf.a -ldl -lcurl -lssl -lcrypto -lz
>    -install_name  /usr/local/lib/libgdal.1.dylib
> -Wl,-compatibility_version -Wl,15 -Wl,-current_version -Wl,15.0
> Undefined symbols:
>    "OGRGeometry::dumpReadable(__sFILE*, char const*) const", referenced
> from: vtable for OGRMultiPointin ogrmultipoint.o
>        vtable for OGRMultiLineStringin ogrmultilinestring.o
> ld: symbol(s) not found
> collect2: ld returned 1 exit status
> make[1]: *** [libgdal.la] Error 1
> make: *** [check-lib] Error 2
> Joaquim Luis
> This message was sent using IMP, the Internet Messaging Program.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
