[gdal-dev] Errors in compiling GDAL on a 64bits Linux
Limei Ran lran at unc.edu
Mon Jun 22 09:24:44 EDT 2009
Hi:
I configured it with the commands:
1. ./setenv CFLAGS "-fPIC"
2. ./configure
--prefix=/nas/uncch/depts/cep/emc/lran/mims/sa_06_2009/src/libs/gdal-1.6.1/local
--with-static-proj4=/nas/uncch/depts/cep/emc/lran/mims/sa_06_2009/src/libs/proj-4.6.1/local --with-hdf5=/nas/uncch/depts/cep/emc/lran/mims/sa_06_2009/src/libs/hdf5-1.8.3/local  --with-libtiff=internal  --without-curl --without-expat
--without-mysql
Then, ./make
Here are new errors I got:
/nas/uncch/depts/cep/emc/lran/mims/sa_06_2009/src/libs/gdal-1.6.1/.libs/libgdal.so:
undefined reference to `XML_ErrorString'
undefined reference to `curl_easy_setopt'
undefined reference to `XML_GetCurrentColumnNumber'
undefined reference to `curl_easy_getinfo'
undefined reference to `curl_slist_free_all'
undefined reference to `curl_multi_init'
undefined reference to `curl_multi_fdset'
collect2: ld returned 1 exit status
make[1]: *** [gdalinfo] Error 1
make[1]: Leaving directory
`/nas/uncch/depts/cep/emc/lran/mims/sa_06_2009/src/libs/gdal-1.6.1/apps'
make: *** [apps-target] Error 2
I told not to use curl, expat, and mysql.  But, I do not know why errors
related to curl are there.
Thank you for your help.
Limei
Limei Ran, Research Associate
Center for Environmental Modeling for Policy Development
the Institute for the Environment University of North Carolina at Chapel Hill
Bank of American Plaza - CB#6116
137 E. Franklin, Room 661
Chapel Hill, NC 27599-6116
Email: lran at unc.edu
Phone:  919-966-2245
Fax:    919-843-3113
