[gdal-dev] Tests fail on buildbot
Mateusz Loskot mateusz at loskot.net
Sun Jun 21 14:34:44 EDT 2009
Frank Warmerdam wrote:
> Mateusz Loskot wrote:
>> Hi,
>> I've noticed tests fail on most builders and there is message like this:
>> "As GDAL_DOWNLOAD_TEST_DATA environment variable is not defined, 40
>> tests relying on data to downloaded from the Web have been skipped"
>> Is this something I should configure for GDAL on Buildbot?
>> If yes, what values should I set for this env variable?
> Mateusz,
> I'd prefer we not enable this while the build slaves are still on
> buildbot.osgeo.org.  This could be turned on when the slaves have
> been migrated to buildtest.osgeo.org.
Frank,
OK, works for me. Just let me know when/where to migrate the stuff.
> The errors I notice on the windows tests are just a wms connection problem
> and there isn't really much action to address them.
Understood.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
