[gdal-dev] Is it a big thing to change ECW to support 16-bit imagery?
Mateusz Loskot mateusz at loskot.net
Sat Mar 28 13:48:09 EDT 2009
mohwawang wrote:
> If you know that the technical problem can not be resolved easily
> (for example, if the deep part of the algorithm is based on 8bit and
> it needs a new algorithm for 16bit) then you have little incentive to
> negotiate the license.
In order to be sure if something is feasible or not, you have to
investigate it, make some a research. Then you will know if you can
implement things easy or not.
My point is that it does *not* make sense to make an attempt on
investigating it if you don't know you are allowed to do it or not.
Otherwise you can spend hours on developing things and eventually
you will lock it in a drawer and nobody will see you work.
That would be quite pointless.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
