[gdal-dev] Status of Spatialite support
Armin Burger armin.burger at gmx.net
Sat May 23 06:48:05 EDT 2009
Even
thanks again. Now it works.
armin
On 23/05/2009 11:32, Even Rouault wrote:
> Armin,
> The path behind the --with-spatialite flag must be the "prefix" of
> installation of spatialite, not the path to the include files. In your case,
> I'd try --with-spatialite=/usr/local.
> It will search a libspatialite.so in /usr/local/lib, and the following include
> files : /usr/local/include/spatialite.h
> and  /usr/local/include/spatialite/sqlite3.h
> Note that I've done my tests with the libspatialite-linux-x86-2.3.0.tar.gz
> archive.
> FYI, the 'spatialite_init' is a function that is looked in the
> libspatialite.so. It is not a separate file.
> Best regards,
> Even
> Le Saturday 23 May 2009 11:03:19 Armin Burger, vous avez écrit :
>> Even
>> thanks for the reply. I downloaded the 1.7 dev version and used the flag
>> --with-spatialite=/usr/local/include/spatialite
>> But the configure output was
>> checking for SpatiaLite... checking for spatialite_init in
>> -lspatialite... yes
>> disabled
>> and then from the summary at the end:
>>   SpatiaLite support:        no
>> The installation of the spatialite libraries did no add a
>> 'spatialite_init' file. All files installed were under
>> /usr/local/include/ and /usr/local/lib.
>> Is there anything to change for running configure?
>> Best regards
>> Armin
>> On 22/05/2009 12:13, Even Rouault wrote:
>>> Armin,
>>> There is already some spatialite support in GDAL 1.6 that enables to read
>>> simple SpatiaLite geometries (point, linestring, polygon) without needing
>>> to link against libspatialite.
>>> In GDAL 1.7dev, write support has also been added, as well as creating
>>> SpatiaLite compatible databases.
>>> Yesterday, I've finally added the (optionnal) capability to link against
>>> libspatialite instead of libsqlite3, to benefit from the spatial enabled
>>> SQL functions that it provides (spatial queries + spatial indexing). So
>>> spatialite support should be mostly complete by now.
>>> You should be able to take the ogr/ogrsf_frmts/sqlite directory from
>>> trunk in GDAL 1.6, but if you want to benefit from linking against
>>> libspatialite, you'll also have to patch configure and GDALmakeopt.in.
>>> See
>>> http://trac.osgeo.org/gdal/changeset/17083
>>> For the sake of simplicity, if you don't have to deal with sticking to
>>> GDAL 1.6 ABI, I'd advise you to grab a snapshot from GDAL 1.7dev.
>>> Best regards,
>>> Even
>>> Le Friday 22 May 2009 11:13:46, vous avez écrit :
>>>> Hi everybody
>>>> I would like to test the spatialite format that should be supported by
>>>> gdal starting with v1.7. Is it already working in current dev version (I
>>>> would mainly need the read functionality with spatial index support in
>>>> interaction with Mapserver)?
>>>> Would I need to take the full export of current trunk or could I just
>>>> use gdal 1.6 and add the sqlite directory from trunk?
>>>> Thanks for any help
>>>> Armin
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
