[gdal-dev] ogr2ogr encoding [RESOLVED]
    Alexandre Dube
    adube at mapgears.com
    Thu May 28 08:48:18 EDT 2009
Hi Frank,
Alexandre Dube wrote:
> I tried to set PGCLIENTENCODING to LATIN1 but I got the same error.
> My terminal is also set to latin1 and when I get the error I can see
> the character correctly.  Changing it to utf8, I see a <?> character
> instead, so I assume the dbf is in latin1.
> Is there a way I could be sure of the dbf encoding ?  It's a file from
> the tiger data set, maybe someone already know that ?  I checked in
> the tiger doc but didn't find anything.
> Thanks,
My bad !  I thought that :
PGCLIENTENCODING=LATIN1;
was enough since using echo $PGCLIENTENCODING returned my value, but it
was not actually set.  Doing this worked :
export PGCLIENTENCODING=LATIN1;
(still learning a lot in linux...)
Many thanks,
Alexandre Dubé
Mapgears
www.mapgears.com
