[gdal-dev] GDAL scripting with Python 2.5 (on windows)
Aleksey Naumov anaumov at gmail.com
Wed Oct 21 18:14:46 EDT 2009
On Wed, Oct 21, 2009 at 1:56 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Ivan wrote:
>> Aleksey,
>>   Thank you, this works. I must have overlooked the gdal-python bindings
>>>  package in the Advanced settings on my last try.
>> Welcome.
>>   One thing I am currently missing in OSGeo4W GDAL is support for ECW and
>>>  MrSID -- is it available? I've installed the gdal-ecw and gdal-mrsid
>>>  packages, but it seems I am missing the DLLs. E.g. when I try "gdalinfo
>>>  --formats" I get complaints:
>>>  ERROR 1: Can't load requested DLL:
>>>  C:\OSGeo4W\apps\gdal-16\bin\gdalplugins\gdal_ECW_JP2ECW.dll
>>>  126: The specified module could not be found.
>>>  C:\OSGeo4W\apps\gdal-16\bin\gdalplugins\gdal_MrSID.dll
>>>   Have tried this with both gdal-* and gdal16-* packages. And remembered
>>> to
>>>  run gdal16.bat to activate the GDAL 1.6 environment. However, can't get
>>>  ECW and MrSID support.
>>>   I suspect this is due to licensing issues. Do I need to install support
>>>  for these formats separately?
>> Yes, you need to get the SDKs from Erdas and Lizartech.
>> See the GDAL supported format list for information:
>> http://www.gdal.org/formats_list.html
Frank,
Thank you for these links, everything worked very well. It turns out all I
had to do for MrSID is reinstall gdal16-mrsid a few times, after that all
DLLs were found.
ECW also worked fine after downloading the SDK, as per instructions on
http://trac.osgeo.org/osgeo4w/wiki/pkg-gdal-ecw.
Overall, it is impressive how well OSGeo4W manages to package all these
software pieces...
Take care,
Aleksey
Aleksey,
> I would add that the OSGeo4W package pages for these packages have
> additional details:
>  http://trac.osgeo.org/osgeo4w/wiki/pkg-gdal-mrsid
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091021/2469a6a1/attachment.html
