[gdal-dev] gdal java binding jpip
Even Rouault even.rouault at mines-paris.org
Mon Oct 26 14:15:57 EDT 2009
Selon "Kunzman, Douglas" <DKUNZMAN at overwatch.textron.com>:
I haven't tried compiling Norman's sandbox, but could you retry with just SVN
trunk and see if you still get the error ? The SWIG version you use is also an
important factor as it breaks quite easily when you switch from one version to
another one. Trunk Java bindings are known to build fine with swig 1.3.39.
> I am trying to compile the java samples under
> http://svn.osgeo.org/gdal/sandbox/normanb/
> <http://svn.osgeo.org/gdal/sandbox/normanb/>  for use with jpip.  I
> believe this is a general gdal compile issue but I'm not sure.  I'm new
> to gdal and have searched the web and have found no good information.
> When I type
> swig> -f makefile.vc java
> Using Visual Studio 2005 and Win32/XP
> I get the following error message,
>         C:\Program Files\Microsoft Visual Studio
> 8\VC\INCLUDE\string.h(215) : see declaration of 'stricmp'
> gdal_wrap.cpp(1129) : warning C4996: 'stricmp': The POSIX name for this
> item is
> deprecated. Instead, use the ISO C++ conformant name: _stricmp. See
> online help
> for details.
> gdal_wrap.cpp(4412) : error C2451: conditional expression of type 'void'
> is illegal
>         Expressions of type void cannot be converted to other types
> gdal_wrap.cpp(4412) : error C2541: 'delete' : cannot delete objects that
> are not
>  pointers
> gdal_wrap.cpp(4414) : error C2120: 'void' illegal with all types
> I have been looked at the error message and they are implying that
> gdal_wrapp.cpp is not standard C++?  Is this possible?
> Any help would be appreciated,
> Thanks Doug
