[Gdal-dev] How to save picture into bmp-file?
Wed Sep 2 09:27:05 EDT 2009
ryabis wrote:
> Sorry, but I`m just started to use C++ and GDAL library... :thinking:
> I have opened the image, using this code:
> 	    poBand_1->RasterIO( GF_Read, x_off, y_off, xsize, ysize, pafScanline,
> xsize, ysize, GDT_Byte, 1, xsize );
>     if (poBand->RasterIO( GF_Write, 0, 0, 512, 512, abyRaster, 512, 512,
> GDT_Byte, 0, 0 ) == CE_Failure)
> What should I write instead of abyRaster?
Ryabis,
You would presumably need to read the region from the source file as you
did above for one band images into pafScanline, and then write that
same buffer into the output file in plcae of abyRaster.
Best regards,
