[gdal-dev] Problem converting .gml to shapefile
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Sep 22 23:23:00 EDT 2009
Adrian,
There is something wrong with the file you gave. So the problem seems
with ogr2ogr (at least with yours).
Please try a clean start without using the -append option and try
again. Let me know as many details as you can, even if you get a
correct result.
On Tue, Sep 22, 2009 at 11:10 PM, Adrián Ribao Martínez
<aribao at gmail.com> wrote:
> Hello Chaitanya,
> I attach the files to this mail.
> Thank you very much for your help!
> Best regards,
> Adrian
> On Martes, 22 de Septiembre de 2009 18:28:37 usted escribió:
>> Adrian,
>> May be the problem is not with the shapefile. Provide a copy of the
>> shapefile you generated to me.
>> Shapefile field names have some limitations. They cannot be longer
>> than 10 chars. http://www.gdal.org/ogr/drv_shapefile.html
>> On Tue, Sep 22, 2009 at 9:09 PM, Adrián Ribao Martínez <aribao at gmail.com> wrote:
>> > On Martes, 22 de Septiembre de 2009 12:41:12 usted escribió:
>> >> Adrian,
>> >> I see the complete map, one similar to the wikipedia version.
>> >> I did this with the latest daily snapshot of gdal with the command:
>> >>   ogr2ogr -f "ESRI Shapefile" limits limits.gml -nlt multipolygon
>> > The version of gdal is 1.6.2 under debian linux. I can see it better in other editors but I still have some problems, the names of the ddbb won't match the features. And when I import it to the ddbb I get the same result as I posted before. http://imgur.com/HDpRp
>> > I'm using geodjango and postgis 1.3.
>> > Regards,
>> > Adrian.
>> >> Please provide the GDAL version you used and see if you can open the
>> >> shapefile in a different application.
>> >> On Tue, Sep 22, 2009 at 3:30 PM, Adrián Ribao Martínez <aribao at gmail.com> wrote:
>> >> > On Martes, 22 de Septiembre de 2009 11:42:44 usted escribió:
>> >> > > Adrian,
>> >> > > The GML file has only one geometry per feature, as far as I looked. I was
>> >> > > able to convert the gml file to shapefile format. It showed boundaries of
>> >> > > different places in Spain including some islands.
>> >> > Are you seeing this map? http://imgur.com/HDpRp
>> >> > This is wrong, the map is not complete, it should be like this: http://en.wikipedia.org/wiki/File:Spain_met.png
>> >> > Regards,
>> >> > Adrian
>> >> > > I did not use the -append option.
>> >> > > On Mon, Sep 21, 2009 at 11:08 PM, Adrián Ribao Martínez <aribao at gmail.com>wrote:
>> >> > > > Hello everybody,
>> >> > > > I have a problem converting a gml file into .shp. I'm using this command:
>> >> > > > ogr2ogr -append -f "ESRI Shapefile" limits limits.gml  -nlt multipolygon
>> >> > > > but it's not working, it seems that only one geometry per feature is
>> >> > > > converted. What am I doing wrong?
>> >> > > > You can have a look at the gml file here:
>> >> > > > http://groups.google.com/group/geodjango/web/limits.gml.tar.gz
>> >> > > > Thank you very much, I've spent all day with this without success.
>> >> > > > Regards,
>> >> > > > Adrian
>> >> > > > _______________________________________________
>> >> > > > gdal-dev mailing list
>> >> > > > gdal-dev at lists.osgeo.org
>> >> > > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> >> Best regards,
>> >> Chaitanya kumar CH.
Best regards,
Chaitanya kumar CH.
