答复: [gdal-dev] Why cannot I get all fields from s57 files with method GetFieldAsString?
Randy randyqiuxy at hotmail.com
Sun Sep 27 09:21:35 EDT 2009
Mr Chaitanya and list,
   You are so kind and help me again and again. Thanks for your help very much!
Now, I can get more fields of a feature like ORNT、USAG after setting environment variable OGR_S57_OPTIONS =
"RETURN_LINKAGES=ON,RETURN_PRIMITIVE=ON,RETURN_REFS=ON".
However, I don’t think I've got the feature's attribute field. For instance, I got a point symbol and its OBJL=159 which means it was a Wreck symbol and I thought I should get some info like CATWRK=.. QUASOU=...if I can get its attribute field.
Then can you tell me whether I can do something else for this?
Thanks a lot!
Best Regards,
Randy
-----邮件原件-----
发件人: Chaitanya kumar CH [mailto:chaitanya.ch at gmail.com]
发送时间: 2009年9月26日 20:51
收件人: Randy
抄送: GDAL/OGR mailing list
主题: Re: [gdal-dev] Why cannot I get all fields from s57 files with method GetFieldAsString?
Randy,
You need to set the environment variable OGR_S57_OPTIONS =
"RETURN_LINKAGES=ON" for the driver to return the FSPT group
attributes.
It is described in http://www.gdal.org/ogr/drv_s57.html
2009/9/26 Randy <randyqiuxy at hotmail.com>:
> Hi list,
> Under Mr Frank and Mr Chaitanya’s guidance, I try to get every feature’s
> field(including its name and value). But I find that I cannot get all
> fields. The following is my code snippet(in MFC):
>                     CString strEnd=”\r\n”;
>                        int nFieldCount=0;
> for(nFieldCount=0;nFieldCount<poFeature->GetFieldCount();nFieldCount++)
> poFieldDefn=poFeature->GetFieldDefnRef(nFieldCount);
>                            fieldName=poFieldDefn->GetNameRef();
> fileFieldAttr.Write(fieldName,strlen(fieldName));
>     outputFieldAttr=poFeature->GetFieldAsString(nFieldCount);
> fileFieldAttr.Write(outputFieldAttr+strEnd,strlen(outputFieldAttr)+2);
> Then, what I got was as follows:
> RCID3
> PRIM1
> GRUP2
> OBJL9
> RVER1
> AGEN550
> FIDN344289455
> FIDS2233
> LNAM0226148570AF08B9
> LNAM_REFS(2:02261485702E08B9,02261485703208B9)
> FFPT_RIND(2:2,2)
> RCID4
> PRIM1
> GRUP2
> OBJL39
> It means that I didn’t get the feature’s attribute field(ATTF) like
> ATTL、ATVL and feature’s FSPT field(Feature Record to Spatial Record Pointer)
> like ORNT、USAG、MASK.
> Then who can tell me what’s wrong with my code?
> Thanks a lot!!!
> Best Regards,
> Randy.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
