[gdal-dev] Re: can ogr2ogr split polygons that cross 180 degree longitude
Even Rouault even.rouault at mines-paris.org
Wed Sep 30 14:25:32 EDT 2009
Selon Hermann Peifer <peifer at gmx.eu>:
The crash was due to a bug in my code in fact. I've also reworked the algorithm
to operate on single polygons instead of multipolygons. That seems to be enough
to avoid triggering the GEOS topology exception in the countries.shp case. So if
you apply r17716 + r17717, it should work ok for your test case.
> Even Rouault wrote:
> > Selon Mateusz Loskot <mateusz at loskot.net>:
> > The output message doesn't enable us to know where the crash occurs : in
> GEOS or
> > in GDAL. If it was in GDAL, I've tried in r17712 + r17713 to be more robust
> if
> > both intersections are NULL and hopefully avoid it. No warranty, I couldn't
> > reproduce your precise issue. If it still persists, attaching a debugger
> and
> > reporting the stack trace when it segfaults might be helpful.
> Unfortunately,  r17712 + r17713 did not make a difference. I uploaded my
> shapefile to http://tinyurl.com/yjpakj2
> Hermann
