[gdal-dev] Setting ENVI .hdr band names
Thu Apr 1 16:28:56 EDT 2010
Benjamin Welton wrote:
> Hey all,
>    Im wondering if its possible to set the band names that appear in the
> ENVI header file instead of having the default band 1, band 2,....
> (which looks kinda messy)
Reviewing the current envidataset.cpp code, it seems that either band_names
and wavelength fields are used for the band descriptions if they are available.
Are you using GDAL 1.7+?  If so, perhaps you could file a ticket on the
issue and attach your envi header file.
Best regards,
