[gdal-dev] read envisat with gdal
menglong yan yanmenglong at gmail.com
Fri Apr 2 20:44:55 EDT 2010
Hi, I want to read envisat with gdal, and I can read the data
successfully. However I can not get the header information such as
"FIRST_MID_LAT"(this item could be
found with  NEST(Next ESA SAR toolbox)) with
GDALDataset::GetMetadataItem("FIRST_MID_LAT"). I have read the souce
code in /frmts/envisat/, and I am sure it is
right to call this function. I turn to Anybody who once did this job
for some advice. Thank you!
Kind regards.
