[gdal-dev] c# binding and .net4
Tamas Szekeres szekerest at gmail.com
Thu Aug 5 13:41:08 EDT 2010
2010/8/5 Ari Jolma <ari.jolma at gmail.com>
> Tamas Szekeres wrote:
>> I've now updated the GDAL csharp bindings to include that fix which
>> already exists in SWIG 2.0.
>> Upgrading the bindings to support SWIG 2.0 would be quite complicated due
>> to several backward incompatible changes introduced from versions to
>> versions.
>> In addition we have a number of local fixes to rework the original
>> behaviour of SWIG causing further memory issues with the .NET garbage
>> collection. These problems hasn't yet been included in the SWIG codebase
>> (and I'm not sure it will ever be added) make that impossible to use SWIG as
>> it stands in the GDAL C# bindings.
>>  Tamas,
> Are you saying here that C# swig bindings are stuck with 1.3.40 (or what is
> the official version of swig that we use, in my Ubuntu I have 1.3.36)? I
> believe that eventually we need to move to using 2.0.
Ari,
It may eventually work but hasn't been tested by me. My automated builders
at http://vbkto.dyndns.org/sdk use 1.3.39 for all bindings.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100805/66ad06e1/attachment.html
