[gdal-dev] get back a layer objet with ogr in python
Ludovic Granjon ludovic.granjon at u-bourgogne.fr
Thu Aug 5 03:23:08 EDT 2010
Hello
I'm trying to develop with ogr in python. I'm on ubuntu 10.4 and I use
gdal 1.7
When I try to get back a layer object from a function, I have the
following message when I do python monscript.py :
"Erreur de segmentation"
This is my code :
# import modules
from osgeo import ogr
def openShapeLine(shapefile):
     #Ouverture du shapefile avec ogr
     driver = ogr.GetDriverByName("ESRI Shapefile")
     datasource = driver.Open(shapefile)
     layer = datasource.GetLayer()
     return (layer)
couche = openShapeLine('/data/axe.shp')
print couche.GetName()
If I do a "print layer.GetName()" inside the openShapeLine function,
there's no problem ...
Have you any idea ?
Thanks all
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100805/8edfa951/ludovic_granjon.vcf
