[gdal-dev] Re: Artifacts when presenting WMS based on a number of adjoining vrt files with overviews
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Mon Aug 23 12:24:26 EDT 2010
jonas nielsen <jonasln <at> gmail.com> writes:
> Help would
> be sincerely appreciated:
> We are
> seeing artifacts when presenting WMS images based on a number of adjoining .vrt
> files with overviews.
What are the dimensions in pixels of the original images with 10 cm pixel size?
Is it right that you are seeing artifacts even if you do not reproject the layer
for output?
-Jukka Rahkonen-
