[gdal-dev] nonspatial column with ogr.
Frank Warmerdam
warmerdam at pobox.com
Tue Aug 24 11:08:31 EDT 2010
ahmet temiz wrote:
> hello
> I can create spatial column. But I don't know how I can create
> nonspatial column with ogr in gdal-java.
> something like column "name" and its value "xxxx"
Ahmet,
I believe you are looking for the CreateField() method on the OGR Layer
class. Note that it does not provide a mechanism to populate the new
column with a particular value for pre-existing features.
http://www.gdal.org/java/org/gdal/ogr/Layer.html#CreateField%28org.gdal.ogr.FieldDefn,%20int%29
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
