[gdal-dev] GDALDeregister_GTiff()
David Hildebrand David.Hildebrand at afsc.ca
Thu Dec 9 16:50:48 EST 2010
Frank:
I turned on CPL_DEBUG in my apache local configuration file and
re-started the server.  However, I am getting no other messages.
Incidentally, I am posting messages to the mapserver-users list with
respect to my problem of displaying 3-band images.
Thanks for your help.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <http://www.afsc.ca>
This communication is intended for the use of the recipient to which it
is addressed, and may contain confidential, personal and/or privileged
information. Please contact Agriculture Financial Services Corporation
immediately if you are not the intended recipient of this communication,
and do not copy, distribute, or take action relying on it. Any
communication received in error, or subsequent reply, should be deleted
or destroyed. Please consider the environment before printing this
email.
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam
Sent: Thursday, December 09, 2010 2:13 PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] GDALDeregister_GTiff()
On 10-12-09 04:06 PM, David Hildebrand wrote:
> I'm not sure if this is the right list to post this question or not.
I
> have a MapServer application built with GDAL support but when I try to
> access a 3-band TIFF image I get the error "GDAL:
> called.\r" showing up in my log file.  Does anyone know what the
> GDALDeregister_GTiff() method is supposed to do?  I've been looking
> through the GDAL documentation and I can't seem to find a reference to
> the method.
David,
It is an information debug message, not an error.  It indicates that
the GeoTIFF driver is being cleaned up - presumably in msCleanup().
While it isn't particularly valuable to know about this specific driver
I have left it in as a marker that more general cleanup is occuring.
GDAL debug output is controlled by the CPL_DEBUG environment variable
which I imagine you have turned on.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
