Re: [gdal-dev] libecwj2 ?
Ivan Lucena ivan.lucena at pmldnet.com
Tue Dec 14 09:53:20 EST 2010
Øyvind,
There is a new SDK that you can download from Erdas website:
http://www.erdas.com/products/ERDASECWJPEG2000SDK/Downloads.aspx
But there are a few changes you would need to do in order to compile the GDAL/ECW driver because the path and library names has changed.
Regards,
Ivan
>  -------Original Message-------
>  From: Oyvind Idland <oyvind.idland at gmail.com>
>  To: gdal-dev at lists.osgeo.org
>  Subject: [gdal-dev] libecwj2 ?
>  Sent: Dec 14 '10 07:09
>  Hello,
>  i am compiling GDAL from source, and need the ECW as plugin.
>  The package is mentioned on the site, libecwj2-3.3-2006-09-06.zip, is this
>  a package
>  from ERDAS ? I tried to find some info about it on their site, but found
>  nothing..
>  I found a couple of other download links, so I can at least get started.
>  -- Øyvind
>  _______________________________________________
>  gdal-dev mailing list
>  [LINK: compose.php?to=gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
>  [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
