AW: [gdal-dev] An issue about using GDALWARP to do theNTv2transformation
Schmitz, Uwe uwe.schmitz at bezreg-koeln.nrw.de
Mon Dec 20 09:12:55 EST 2010
Heng,
> http://osgeo-org.1803224.n2.nabble.com/file/n5848200/gdalwarp_
> problem1.doc
> gdalwarp_problem1.doc
> Hi Uwe,
> I have tried your suggestion on the same raster file with a modified
> "+x_0=500000" parameter in the command line (as seen in the
> attached doc). I
> could see the major difference:there is still one error
> message left. When I
> tried on another raster file with the same modified
> parameter, I have got
> much less error messages than before. However, is it still
> possible that my
> raster data are outside the area of the grid shift file? All
> the raster data
> I was trying to transform are GK (DHDN) zone 4, which false
> easting value is
> 4500000. This was why I used "+x_0=4500000" instead of
> "+x_0=500000" in the
> command line. As I am getting to know all these georeference
> settings at the
> moment, can you tell me why you suggested the modified
> parameter and what
> you meant about "raster data lacks the Gauss-Krueger meridian prefix"?
that was just a guess, because your coordinates lie far in the
west of DHDN/GK zone 4.
Normally DHDN/GK coordinates are noted as e.g.:
4500000.0 Rechts 5500000.0 Hoch
Omitting the Gauss-Krueger meridian prefix you have:
(Note: Rechts coordinate has only six digits) an thats
far in the west of the real position. It's very simple and
therefore you may give it a try.
If it's not the case, may be you can post the output of:
gdalinfo l0.tif
That would help to see, if the file is correctly georeferenced.
Regards
Uwe
