[gdal-dev] Proposal: gdal_muladd.py
Antonio Valentino antonio.valentino at tiscali.it
Mon Feb 1 03:08:48 EST 2010
Hi Greg,
Il giorno Sun, 31 Jan 2010 14:58:19 -0500
Greg Coats <gregcoats at mac.com> ha scritto:
> Regarding the diff function
> "diff": computes the difference between 2 raster bands (b1 - b2)
> Since the result of diff could be a negative number, for example
> 99-150=-51, I suggest that there be an additional function that
> provides the absolute value of diff, which would be 51 in this
> example. Greg
Of course, it would not be a problem to include but my original idea
was to provide only base functions and use them to get complex
expressions.
In this case, what you need can be obtained using two stacked virtual
files:
 - diff (using appropriate band data type and SourceTransferType)
 - mod
Is it a reasonable approach for you?
Even more interesting for common tasks should be to compute
abs((b1-b2)/(b1+b2))
> On Jan 31, 2010, at 12:18 PM, Antonio Valentino wrote:
> > Hi Matt,
> > Il giorno Mon, 25 Jan 2010 20:57:58 -0600
> > Matt Klaric <matt at klaric.com> ha scritto:
> >> On Mon, Jan 25, 2010 at 8:38 PM, Frank Warmerdam
> >> <warmerdam at pobox.com>wrote:
> >>> I don't think the VRT approach supports actually adding
> >>> different images together, only overlaying and rescaling.
> >> However, pixel functions could be used in a VRT file to accomplish
> >> the desired outcome.
> >> --matt
> > Indeed, it would require a pixel function for sum and the ScaleRatio
> > property of ComplexSource.
> > I have just submitted a patch
> > http://trac.osgeo.org/gdal/ticket/3367
> > that provides a set of standard pixel functions, including sum (of 2
> > or more raster bands).
> > Using this set of functions it should be quite easy to write a
> > python program that performs generic bands arithmetic.
best regards
Antonio Valentino
