Re: [gdal-dev] How to supress std io of gdal?
Ivan Lucena ivan.lucena at
Fri Feb 12 08:35:25 EST 2010
>  Is there a way to redirect it to some other buffer? Like an internal stream which can then be properly propagated via exceptions or written into a log?
It is probably not as sophisticated as you want or need but have you tried that:
gdalinfo out.tif > stdout.txt 2> stderr.txt
>  Thanks
>  Sam
>  NEU: Mit GMX DSL über 1000,- ¿ sparen!
>  _______________________________________________
>  gdal-dev mailing list
>  gdal-dev at
