[gdal-dev] Length method for geometries in bindings
Ari Jolma ari.jolma at gmail.com
Thu Feb 18 11:16:18 EST 2010
Frank Warmerdam wrote:
> Ari Jolma wrote:
>> Folks,
>> I added a Length() method for geometries into bindings. The method
>> re-dos a simple euclidean distance as the get_Length of OGR proper is
>> not exposed.
> Ari,
> I'm not clear on why you reimplemented it for the bindings instead of
> just exposing it from the core, and adding a binding around it.
I simply don't feel confident enough on changing the C API as I've so
far only worked on the bindings.
>> I hope this is ok. Length is in OGC SF with that name. However, the
>> standard specifies that the length should be in its associated
>> spatial reference and that's not the case here.
> I don't understand this statement.  In what way is the length not being
> returned in the linear measure of the spatial referenced associated with
> the geometry?  It seems to be - it seems to me something special would
> need to be done to make that not-true.
For example if the data is in geographic coordinates then the distance
between two points is not euclidean distance.
Regards,
Ari
> Best regards,
