[gdal-dev] Length method for geometries in bindings
Thu Feb 18 09:56:44 EST 2010
Ari Jolma wrote:
> Folks,
> I added a Length() method for geometries into bindings. The method
> re-dos a simple euclidean distance as the get_Length of OGR proper is
> not exposed.
Ari,
I'm not clear on why you reimplemented it for the bindings instead of
just exposing it from the core, and adding a binding around it.
> I hope this is ok. Length is in OGC SF with that name. However, the
> standard specifies that the length should be in its associated spatial
> reference and that's not the case here.
I don't understand this statement.  In what way is the length not being
returned in the linear measure of the spatial referenced associated with
the geometry?  It seems to be - it seems to me something special would
need to be done to make that not-true.
Best regards,
