[gdal-dev] ogrinfo with remote KML-urls
Mateusz Loskot mateusz at loskot.net
Tue Feb 23 15:04:19 EST 2010
Frank Warmerdam wrote:
> Mateusz Loskot wrote:
>>> It *seems* like a bad idea to embed such behavior in a particular
>>> driver.
>> Yes, I understand your point. Perhaps I should narrow the test with
>> check if URL consists of "geojson" token, like
>> http://server/path/geojson/1234 or ftp://server/path/file.geojson
>> and if not present, then no remote reading would be performed.
>> Should I?
> Mateusz,
> If there was a typical extension for geojson files that would be
> helpful.
Looking at http://featureserver.org/ I suppose a typical extension
is .json but I sort of proposed also .geojson.
I mean, URLs may include string "geojson" as a format request,
so I meant this
as specific format request (following RESTful thing):
http://server/path/gml/1234
http://server/path/kml/1234
etc.
> Alternatively, we could take this out of the geojson driver, and
> handle it more like GDAL where we have a final "http" driver that
> will fetch http results and then re-invoke OGROpen() on the resulting
> downloaded file.   Then all the drivers again have a crack at the
> file.
> This would make it work for kml, for instance, and would sure we
> don't end up downloading it several times if the logic ends up in
> several drivers.
OK, no problem for me to disable it. Should I?
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
