[gdal-dev] gdal_translate with -a_srs option using proj4 syntax and +a=ellipsoid
Fri Feb 26 12:37:21 EST 2010
Cassanova, Bill wrote:
> ***First step is to add the geographic information to the tiff*:
> gdal_translate -a_ullr -3507992.25 6780696 3601343.75 2337361-a_srs
> "+proj=merc +lon_0=96w +a=6378206.5 +f=0.00339" src_image.tiff
> dest_image.tiff
> The failure I get is:
> Failed to process SRS definition: +proj=merc +lon_0=96w +a=6378206.5
> +f=0.00339
Bill,
Unfortunately the OGRSpatialReference PROJ.4 parser does not support
the +f flag, but it does support +rf (inverse flattening).  Try
using +rf=294.98525 instead of the +f parameter.
If you wish, you could file an enhancement ticket requesting that
support for +f be added.
> The problem I am now having is that I bring this image into ArcInfo and
> for some reason it is shifted north.  I think that being able to
> correctly apply the ellipsoid equator radius and ellipsoid flattening
> may fix my problem or am I missing something?
> ***The second step is to create an un****-****projected image from this
> data*:
> My presumption is the below command will accomplish
> Just that:
> gdalwarp -t_srs '+proj=latlong' -r ${sample_method} ${tmp_image_3}
> ${final_image
You should be specific about the target earth model by adding
something like +datum=WGS84 into the -t_srs string.
Otherwise the approach is plausible.
Best regards,
