[gdal-dev] ogr vfk and write access - Updates on 1.7.0 release plan
Martin Landa landa.martin at gmail.com
Thu Jan 7 08:44:43 EST 2010
2010/1/6 Even Rouault <even.rouault at mines-paris.org>:
> 1.7.0-beta2 very soon, but as it is not issued yet, it still gives you the
> opportunity to commit the driver if you're confident enough it won't cause
> too much build problems. If so, please commit the code very soon. Otherwise
I committed the code in r18449. The driver is not compiled by default.
Tested on GNU/Linux with
g++ 4.3.4, compilation using VC compiler in progress.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
