[gdal-dev] Re: buiding gdal with Visual C++ 2008
Martin Landa landa.martin at gmail.com
Thu Jan 7 11:41:37 EST 2010
2010/1/7 Even Rouault <even.rouault at mines-paris.org>:
> For the Win32 support of your driver, I've observed a typo in the makefile.vc :
> the objects extensions should be .obj, not .o. Otherwise I feel like you might
> have missed a few additions in a few files in ogr/ subtree. A pragrmatic way is
> to issue "grep -r dxf ogr/" to see all places where the DXF driver was
> referenced. You likely need to add support for your VFK driver in the same files
> similarly to what is done for DXF. ogr/ogrsf_frmts/makefile.vc is one of the
> file for example that comes to mind.
hopefully fixed in r18453 & r18454 (untested due to my problems with
building GDAL using VC).
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
