[gdal-dev] Re: buiding gdal with Visual C++ 2008
Martin Landa landa.martin at gmail.com
Thu Jan 7 16:47:33 EST 2010
2010/1/7 Even Rouault <even.rouault at mines-paris.org>:
> 3) I've done a few commits to enable Win32 support of the VFK driver and the
> tests pass :-)
thanks...
> 4) I've changed the configure.in logic to enable it on Unix platforms by
> default. I saw no reason for not enabling it by default as there are no
> external dependencies.
Right, I was thinking about that.
> 5) We have reverted your regeneration of configure done with autconf 2.65 to
> re-update it with autoconf 2.61, which is the current "official" version of
> the GDAL project for updating autoconf from autoconf.in. If you need to
> update it in the future, please do it with that one (well, look at the
> comment in the header of current configure to check that this is still the
> current version ;-))
OK.
> 6) I've created ticket http://trac.osgeo.org/gdal/ticket/3314 with a few
> errors detected by Valgrind
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
