[gdal-dev] Projection issue with a netcdf file
Christopher Barker Chris.Barker at noaa.gov
Tue Jan 12 12:13:21 EST 2010
Kyle Shannon wrote:
> I am downloading a netcdf file from a thredds data server.  It contains
> 4 grib datasets of weather data.  When I run gdalinfo on one of these
> subdatasets, the standard parallels in the netCDF metadata (marked by
> astrisks) differs from the standard parallels in the reported Coordinate
> system:
> I am curious where this discrepancy is taking place.  I kind of think it
> is a typo or a mistake from the data server, but I can't peg it down.
> Any thoughts?
have you run ncdump on the netcdf file? That should tell you what's int
eh file, so you can determine if the thredds server is doing the right
thing:
ncdump -h name_of_file.nc
(the -h) means you only want the header info -- not all the data.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
