[gdal-dev] Projection issue with a netcdf file
Kyle Shannon ksshannon at gmail.com
Tue Jan 12 12:41:56 EST 2010
ncdump -h reports the same correct standard parallels (25) whereas
Coordinate System reports 0 for both standard parallels.  It appears the
projection is a Lambert Conformal Conic with 2 standard parallels, but they
are the same effectively making it a lcc with 1 standard parallel.
Kyle Shannon
Physical Science Technician
RMRS Fire Sciences Lab
Fire, Fuels & Smoke - RWU 4405
5775 Highway 10 W.
Missoula, MT 59808
(406)646-6577
kshannon at fs.fed.us
On Tue, Jan 12, 2010 at 10:13 AM, Christopher Barker
<Chris.Barker at noaa.gov>wrote:
> Kyle Shannon wrote:
>> I am downloading a netcdf file from a thredds data server.  It contains 4
>> grib datasets of weather data.  When I run gdalinfo on one of these
>> subdatasets, the standard parallels in the netCDF metadata (marked by
>> astrisks) differs from the standard parallels in the reported Coordinate
>> system:
>  I am curious where this discrepancy is taking place.  I kind of think it
>> is a typo or a mistake from the data server, but I can't peg it down.  Any
>> thoughts?
> have you run ncdump on the netcdf file? That should tell you what's int eh
> file, so you can determine if the thredds server is doing the right thing:
> ncdump -h name_of_file.nc
> (the -h) means you only want the header info -- not all the data.
> -Chris
> Christopher Barker, Ph.D.
> Oceanographer
> Emergency Response Division
> NOAA/NOS/OR&R            (206) 526-6959   voice
> 7600 Sand Point Way NE   (206) 526-6329   fax
> Seattle, WA  98115       (206) 526-6317   main reception
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100112/9df3ad92/attachment.html
