[gdal-dev] Projection issue with a netcdf file
    Christopher Barker
    Chris.Barker at noaa.gov
    Tue Jan 12 13:26:06 EST 2010
Kyle Shannon wrote:
> ncdump -h reports the same correct standard parallels (25) whereas
> Coordinate System reports 0 for both standard parallels.  It appears the
> projection is a Lambert Conformal Conic with 2 standard parallels, but
> they are the same effectively making it a lcc with 1 standard parallel.
It looks like GDAL doesn't understand those parameters:
Georeference
There is no universal way of storing georeferencing in netCDF files. The
driver first tries to follow the CF-1 Convention from UNIDATA looking
for the Metadata named "grid_mapping". If "grid_mapping" is not present,
the driver will try to find an lat/lon grid array to set geotransform
array. The NetCDF driver verifies that the Lat/Lon array is equally space.
If those 2 methods fail, NetCDF driver will try to read the following
metadata directly and set up georefenrencing.
     * spatial_ref (Well Known Text)
So to get the spatial reference right, the netcdf file needs a proper
spatial_ref parameter in WKT format. What does ncdump tell you it has?
If it's not right, you can either get whoever is running your server to
fix it, or you can fix it yourself by processing the nc file with something:
   ncdump-> filter -> ncgen
   NCO utilitites
   python (or perl, or ???) scripts.
good luck!
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
