[gdal-dev] reading VPF format NGA DNCs
Martin Chapman chapmanm at pixia.com
Thu Jan 14 16:26:57 EST 2010
Looks to me like your gltp string is incorrect but I am not the authority on this. I have made it work before with vpf but as I remember you needed to get that gltp string right and I thought you needed to specify the layer with an @ sign. Look at the vpf / ogdi docs under ogr for an example.
Martin
------Original Message------
To: chapmanm at pixia.com
Cc: 'gdal-dev'
Subject: Re: [gdal-dev] reading VPF format NGA DNCs
Sent: Jan 14, 2010 2:21 PM
Martin Chapman wrote:
> Do you have the OGDI driver built and configured into GDAL?
well, orginfo tells me:
FAILURE:
Unable to open datasource `gltp:/vrf/a1611110' with the following drivers.
   -> ESRI Shapefile
   -> MapInfo File
   -> UK .NTF
   -> SDTS
   -> TIGER
   -> S57
   -> DGN
   -> VRT
   -> REC
   -> Memory
   -> BNA
   -> CSV
   -> GML
   -> GPX
   -> KML
   -> GeoJSON
   -> Interlis 1
   -> Interlis 2
   -> GMT
   -> SQLite
   -> DODS
   -> ODBC
   -> PGeo
   -> OGDI
   -> PostgreSQL
   -> MySQL
   -> XPlane
   -> AVCBin
   -> AVCE00
   -> Geoconcept
OGDI is in there -- so I assume that it's built in -- how else can I tell?
thanks,
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
Chris.Barker at noaa.gov
