[gdal-dev] Locking of Open Shapefile
Joel Odom joelodom at gmail.com
Fri Jan 15 09:20:09 EST 2010
I've discovered that when I use OGRSFDriverRegistrar::Open to open a
Shapefile, the file remains locked so that another process can't open the
file until after I've called OGRDataSource::DestroyDataSource.  Is there any
way to prevent the file from being locked?  Thanks!
http://giscoder.blogspot.com/
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100115/82ad2bac/attachment.html
