[gdal-dev] Convert raster from [0,360] to [-180,180]
Pinner, Luke Luke.Pinner at environment.gov.au
Wed Jan 20 19:21:47 EST 2010
Something like the following perhaps?
gdal_translate -projwin 0 90 180 -90 g0-360.tif g0-180.tif
gdal_translate -projwin 180 90 360 -90 -a_ullr -180 90 0 -90 g0-360.tif
g-180-0.tif
gdal_merge[.py] -o g-180-180.tif g0-180.tif  g-180-0.tif
Regards
Luke
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jose Gomez-Dans
Sent: Thursday, 21 January 2010 5:20 AM
To: gdal-dev
Subject: [gdal-dev] Convert raster from [0,360] to [-180,180]
I have some raster files spanning the globe from 0 to 360 degrees
longitude. However, I would rather they be in the -180 to 180 degree
range. While I can do this converting into VRTs and playing around with
the SimpleSource element, I also saw a posting on this list that
suggests that one can easily use gdalwarp for this
<http://lists.osgeo.org/pipermail/gdal-dev/2006-June/009293.html>. The
suggested command is
gdalwarp --config CENTER_LONG 180 openev/utm.tif ll.tif -t_srs WGS84
I have tried this command on my file (which is initially in WGS84 0 to
360), set the value of CENTER_LONG to 0, but I basically get my old
raster back, with the longitudes going from 0 to 360.
Anything other than scripting/VRT editing?
Thanks!
Jose
If you have received this transmission in error please notify us immediately by return e-mail and delete all copies. If this e-mail or any attachments have been sent to you in error, that error does not constitute waiver of any confidentiality, privilege or copyright in respect of information in the e-mail or attachments.
Please consider the environment before printing this email.
