[gdal-dev] Support for GML 3
massimo costantini massimo.costantini at gmail.com
Wed Jan 27 04:59:42 EST 2010
Thank's a lot,
someone know if GML3 support for writing is under costruction or not?
On Tue, Jan 26, 2010 at 8:22 PM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> Massimo,
> it depends on if you're interested by the read side or the write side of the
> GML driver !
> * For the read side, it's designed for GML2 but some GML3 support has been
> added . I see there's at least some support for the <pos> and <posList>
> elements. The best is to try and see if it supports what you're interested
> in !
> * For the write side, GML2 only.
> Best regards,
> Even
> Le Tuesday 26 January 2010 16:46:23 massimo costantini, vous avez écrit :
>> Hi,
>> I'd like to know, the state of the art for the GML3 data format
>> support in ogr2ogr.
>> Thanks
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
