[gdal-dev] 64 bit linux format support
David Boyd dboyd at data-tactics.com
Fri Jan 29 13:55:48 EST 2010
All:
   Sorry for the newbie question.  I have searched archives and not
seen an answer.
   I am setting up a Geoserver system on 64 bit Linux (CENTOS) and
need support for NITF formats.  I installed the lastest imageioext
binaries but none of the additional GDAL formats show up.
I have verified all the paths (LD_LIBRARY_PATH) and such but but
According to the 2.0 docs I should see DTED, EHdr, ERDASImg the MrSID
and NITF formats when I create a new data store.  I downloaded the ECW
version of the libraries.
I have looked all through the docs and the only thing I can figure is
that MrSID support is needed to support NITF and a number of
other formats. That only seems to be available in the 32 bit
versions.
Any ideas/help on where to look or what I might have done
wrong would be appreciated.
========= mailto:dboyd at data-tactics.com ============
David W. Boyd
Director, Engineering, Research and Development
Data Tactics Corporation
7901 Jones Branch, Suite 240
Mclean, VA 22102
office:   +1-703-506-3735, ext 308
fax:     +1-703-506-6703
cell:     +1-703-402-7908
============== http://www.data-tactics.com/ ============
The information contained in this message may be privileged
and/or confidential and protected from disclosure.
If the reader of this message is not the intended recipient
or an employee or agent responsible for delivering this message
to the intended recipient, you are hereby notified that any
dissemination, distribution or copying of this communication
is strictly prohibited.  If you have received this communication
in error, please notify the sender immediately by replying to
this message and deleting the material from any computer.
